Dis-assemble wheel (6 bolts) separate, center spacer lube edges of spacer ensure lube around wheel edges align halves insert into tire (air inlet aligned with dot) tighten bolts evenly, make sure even seating torque to 36ft lbs
check both bearings -remove c-clamp -pull out bearing -douse in grease -re-assemble
