Assembled Rudder Pedal Rush Rods - rivet ends to machined tubes. - trim tubes to align assembly holes - bore out assembly holes Inserted rod ends and jam nuts QC assembled rods
installed rudder push rod bell crank preppred for installing rudder torque tubes & push rods began torque tube installation by installing end plate dis-assembled steering rod installed cabin half of steering rod
removed blowdown nitrogen gas cylinder to repair bracket
