Continued working on both servo mounts and the linkage that connects them to the controls. I also had previously bought two green illuminated 12v, 20 amp rocker switches for the master and avionics switches from Aircraft Spruce. I cut the panel for them but did not like that they just did not snap in tight no matter what I tried. I had decided that I would just except that they weren't going to be the best fit and go ahead and use them anyway. Then when I terminated the wires on them I found out the terminals were loose in the switch :( I ordered different switches that were about the same size from Del City and they seemed to be a much better quality plus they were half the price. I installed them and it is definetly much better.
