Made a frame so that I could work with a sample kit of Oratex. Bent 1/2" aluminum tube and basically made a square with the four corners radiused. Painted the glue on the frame and fabric and will wait for it to dry. I made a bus bar out of a 1/2" wide x 1/8" thick copper bar. I drilled and tapped 8/32" holes on 1/2" centers. Then I mounted the Safety Trim module on one of the plates that are behind the panel.
