Bretts Web Site
Date:  10-8-2018
Number of Hours:  3.00
Brief Description:  Right wing
Started preping the right wing for covering. After seeing how any imperfections really show up under the Oratex I will spend a little extra time trying to get everything smooth before applying the cover. I added more superfil where the transition was a little rough on the leading edge. Once it was dry I sanded it smooth as well as any other areas. I also spent a lot of time sanding the ridges that run lengthwise to the leading edge. They look like they were caused when the leading edges were extruded. I also bought a leather punch set so that I could make nice round covers where I burn in drain holes. I tried it out and it works good.
Punch set
Punch set
Superfil before sanding
