Applied heat to strtech the fabric and then applied heat to each rib in order to activate the glue. After I had everything glued and stretched tight I realized I forgot to put the backing plate where the rear strut bracket is located. I am hoping the Oratex can be stretched in order to get the plate in place. I also made two indentions on the front spar attachment where the attach bolts will be.
