I sprayed Stewarts Systems epoxy primer on the outside of all of the aluminum parts inside the wings. I had hoped to finish but halfway thru my compressor decided to quit which is not good when you have just mixed two part epoxy paint. I got it running again but ran out of daylight and did not want to spray inside a closed garage. One more coat on one wing and I will be done
