Cleaned the inside of the spars with alcohol, then used Stewart Systems two part epoxy to prime the insides for corrosion protection. I thinned the epoxy as directed for spary gun use because any thicker made it difficult to get all the areas covered. I installed tennis balls on each end and tilted the wings back and forth while rolling them as suggested by Kitfox. This all took awhile to complete but it came out good.
