Completed preparing the flaperon hinge brackets. I also alodined and primed them for extra corrosion protection. Formed and installed the sight guage. I used hot water to heat the plastic so it would bend around the forming wire without kinking. Drilled and tapped the mounting holes for the pitot tube. Flared tubes and installed the fittings required to connect the pitot lines to the plastic lines in the wings. Put the last coat of paint on the plate that goes around the sight guage.
