Bretts Web Site
Date:  11-30-2017
Number of Hours:  3.00
Brief Description:  Electrical items
I found a fuse block on amazon that may work. I had to make a bus bar for both sides on the back. Im not sure how good this will work out but we will find out. If it does work it will be a much cheaper alternative to others items you find.The fuse block itself has LED's that light up if the fuse blowes so finding the bad fuse should be quick and easy. I aslo decided that I will install all of the tailfeathers back on so that I can make most of the rigging adjustments now before the covering goes on. I also ordred the trim relays from kitfox so that I will be able to operate the trim from the control column.
front with fuses and indicators
Installed Buss so one Lg wire will power each
