Completed running the sensor wire and installed the trim motor wire as well. The trim sensor came with shielded cable and I decided to use shielded wire on the trim motor as well. I also decided to use plastic tubing cut lengthwise and slid over the top of the metal frame wherever I tiewrapped the wire.
