Bretts Web Site
Date:  10-16-2017
Brief Description:  Brake system
Worked on routing and installing the brake lines. It seems funny that the things that seem to cause other builders problems go great for me, and the things that go easy for everyone else are really difficult for me. This has been the case with the brake line routing. I talked to several builders and there were no issues for others. For me the brakes seemed to take forever to figure the best routing etc. I temporarily tie wrapped everything in place and then checked for clearance with the adjustable pedals in every position possible, and I think I finally have it figured out. I also installed a"Panduit" plastic electrical wirway under the center console to route all the wiring and brake lines toward the front. I drilled the holes in the cover to lighten it as well as to make a place to bring the brake lines straight up to the parking brake valve.
parking brake valve
parking brake valve
