I used the brake hone and it still took quite a bit to get everything to fit. It was mainly because I did not want to over sand the bushings so I did everything in moderation. I then removed the paint where the gear mounts to the fuselage, pressed those bushings in place and used locktite as directed. I tried to mount the gear to the fuselage and could not get the bolts to line up with the holes in the fuselage. It turned out to be the aluminum block on the right was drilled a little wide and won't fit into either mounting bracket. I'm not sure what is the best way to fix it so I'll sleep on it and figure it out later.
