Bretts Web Site
Date:  4-4-2016
Number of Hours:  4.00
Brief Description:  Doors
Sanded Hysol around door trims etc. Worked on fitting the pilot side door and the Lexan panel. After getting the door frame centered I trimmed the Lexan to fit the opening. Reinstalled the frame and Lexan and backdrilled thru the frame into the Lexan with a #40 drillbit applying clecos as I went. I then removed the entire door and drilled the holes to 5/32 and reapplied larger clecos. I was unable to get the crease in the Lexan exactly in line with where the doorframe turns so I used a heatgun to reshape the ends as needed.
Before heating
Before heating
After heating
After heating
