Assemble and install flaperon mixer. Assemble and install flap handle. Assemble and install flap, aileron, and elevator push/pull tubes. I made a block of wood to hold the detent pin in the flap handle for drilling. I also started the hole with a slightly larger bit first in order to make a spot to seat the tiny drill bit. This all worked out well with no broken bits. Also began to fit floor boards.
