Spent most of the day first tacking the outer edges of the fabric drown with the small iron. I like using the small iron because everything goes a lot slower which lessens the chance of me messing up. Once I had it tacked in place I used the heat gun and iron to heat the glue and bond the fabric to all of the outer locations completely around the tubes. After this sets for the required 24hrs I will heat shrink everything in the middle, cut the required holes and glue the fabric to the stringers and cross members
