Used the Toco iron to heat shrink the Oratex on the top of the wing and also wraped and glued the Oratex around the end ribs. I then layed out all of the rib stiching holes, pre punched them and cut the anti chafing strips that go on both the top and bottom of the ribs. Measured the rib lacing cord needed for each rib and dewaxed all of them.
