Completed all the rib taping on the left wing except for the trailing and leading edge. I am going to have the strips that attach to the outer ends of the wings that the wing tips attach to powdered coated. I had painted these previously with spray can paint and really did not like the results. I also had one of the tapes shrink slightly lengthwise exposing some of the glue, I slept on how to best remove the glue and decided to try the bonding agent that they now supply to clean any area prior to applying the tapes and it worked really well. I also tried this on older glue and it softens it as well although I would be very careful in using it on any area other than just cosmetic clean up since it may permanently damage the glue bond.
