Filled around the wing strut attach brackets with superfil and applied a coat of primer. Attached the doilies for the jury struts, tank drain, and pitot tube. For some reason they did not attach smoothly and have a rough appearance. I tried heat and pressure in an effort to try and smooth them out and it did not work. I tried the heat gun as well and that just made them shrink irregularly.
