Bretts Web Site
Date:  6-28-2018
Number of Hours:  3.00
Brief Description:  Left wing
Applied heat to strtech the fabric and then applied heat to each rib in order to activate the glue. After I had everything glued and stretched tight I realized I forgot to put the backing plate where the rear strut bracket is located. I am hoping the Oratex can be stretched in order to get the plate in place. I also made two indentions on the front spar attachment where the attach bolts will be.
Fabric stretched
Fabric stretched
Modified to clear strut bolts
Should have installed the back plate first
