Bretts Web Site
Date:  4-8-2018
Number of Hours:  3.00
Brief Description:  Oratex
Continued working on the covering. I used the Toko Iron to heat and shrink the fabric on the bottom right side of the elevator. I ordered a little cheaper Iron that only goes to 330 deg and it worked just fine. The fabric can be heated and stretched more but others have said the lower temp Iron has worked for them. I also cut the bottom and top fabric for the left side of the elevator and applied the glue to them as well as the glue on the elevator. While I had the Oratex unrolled I also cut the fabric for one side of one wing.
