Continued working on the wiring, mainly behind the panel. The hardware I needed for the servos came in so I worked on them as well. I have the elevator servo bracket made and figured out how to mount it. I temporarily installed the servo and figured out that the controls move further than the servo arm stops:( I know they make a longer arm so I'll check into that or try to figure another way to make it work.
