Bretts Web Site
Date:  2-22-2018
Number of Hours:  3.00
Sprayed the final coat of primer on the wing that I was unable to finish yesterday. Glued the rest of the speed fairings on to the jury struts. Previously I had made some mounts for my static ports. I am not sure if it is a good setup or not but I went ahead and decided to use them and hope for the best. I used the same silcone that is used to hold the fuel tanks to the spars to seal around the static ports and then riveted them to the brackets I made. I also used flush mount rivets to hold them in place. Once that was done I used Hysol to attach the brackets to the fuselage and clamped them in place using wood 1x2's to make sure they were flush with the outer edges of the tubing.
