Since I have removable covers where my rudder cables come out of the fuselage I went ahead and crimped the ends of the cables. I also trimmed the aluminum angles where the rear access panels attach to the fuselage. This was due to when I drilled the holes in the covers I did not realize the tinnerman clips would not reach unless the holes were closer to the edges of the aluminum angles. At first I thought I'll just get longer tinnerman clips but I could not find them anywhere with #4 holes so the only option was to trim them.
