Started assembling the axels on the gear, tubes and tires on the rims, and packed the bearings with grease. I am planning on installing wheelpants and noticed the manual says to install the brackets before installing the axels. I called Debra with Kitfox and she sent the brackets as well as the longer bolts required. This is an option if you don't want to purchase the entire wheelpant kit this early on.
