Bretts Web Site
Date:  1-28-2017
Brief Description:  Left flaperon
Completed sanding the flaperon tip. Drilled holes in flaperon for counter balance weights deburred the holes, then used hysol and rivets to install them. I had to enlarge the hole in both inboard weights at the tip so it would clear the rivet on the trailing edge.
Finished tip & counter weight installed
Enlarged hole for rivet
