Drilled, deburred left flaperon end rib, then applied hysol, installed and riveted into place. Installed foam for tip in the end of the flaperon and hysoled into pllace. I then applied the first coat of hysol over the foam to form the tip. I also installed flush rivets on trailing edge of flaperon in place of pop rivets.
