Drilled holes in flaperons for counter balance weights, then prepped the areas, hysoled and riveted them into place. Applied one coat of Hysol on flaperon tip. I filed grooves into the foam as shown for a little extra strength. Installed plate over site guage on fuel tank. I installed grommets over the plastic lines where they pass through the plates to keep them from possibly getting cut.
