I had the same problem with the false ribs coming lose from the stringers on the right wing so I rouged up the stringers where the ribs attach and rehysoled them. Started working on the wing tip strips that the wingtips attach to. I cut and trimmed them to fit, then drilled the rivet holes, first with a #40 clamping as I went, then drilled them to a #30.
