Reamed wing attachment points,and installed wing and lift struts. Prepped root (end) rib and Hysoled it into place. Started working on butt rib mounting tabs, drilled mounting holes and Hysoled /riveted tabs into place. Drilled the holes for mounting the butt rib to the fuselage. Installed backing strip onto butt rib where windshield mounts. Installed tabs for jury struts on main spars. Installed top and bottom false ribs where lift strut attachment plates are.
