Installed the cover plate that goes around the sight guage on the left wing. Finished making the mount for the left wingtip landing light. I used sticky back weather stripping to pad and seal around the light inside the wingtip. This should also allow me to make slight adjustments to the light as needed for proper alignment. The screws in the photo are just temporary until I can buy A/N hardware. Rearanged the fuselage in the garage so I could begin working on the right wing. Started working on the right wing, reamed fuselage attach points, prepped end rib, and spar stiffiners plates at attachment points.
