Built adjustable rudder pedal levers. The detent pin drilling didn't go as smooth as the flap handle but its atleast done. I dulled two bits before finishing. Drilled and mounted the adjustable rudder pedal detent brackets to the console. Began building the rudder pedal install hardware, and put another coat of varnish on the floorboards.
