Assembled control stick pivots. Figured out the hard way that the beariings that are pressed into the control column need to be placed in position with the control sticks installed for a proper fit. I initally installed the first one bottomed out in the raceway on the column which is to far and it made the control stick out of center. I had to damage the bearing to remove it so a new one is on order. All the others went in with no problems once I learned my lesson.
