Installed fuel transfer tunnel and fuel baffle rib. Installed quick drain block and shaped to teardrop form. Frabricated tank endplate and installed nutplates in wing. Installed the fuel pickup fitting and tube. Flushed fuel tank. Installed fuel sender and tank endplate. Tested tank for leaks.
