Brief Description: Wing Tip Installation Left Wing
Trimmed outer wing skins flush with outboard rib. Installed and fit number 18 rib with fuel vent through rib. Drilled holes in outside ribs for ventilation. Fit wing tip to wing and lengthened the wing tip. Installed the joggle block and aft portion of rib 18 into the wing tip. Installed wing tip lights and installed wing tip to wing. Applied one layer lamanent to wing and wing tip. Checked for aileron travel.
