Assembled canopy frame. Trimmed and fit acrylic shell to canopy frame. Epoxied shell to frame. Core crushed and filled the back edges of the frame. Applied fiberglass stips to acrylic and frame. Installed the front and side rails into the fuslage. Assembled and installed canopy hardware for sliding the canopy. Mounted the front canopy sliding pin. Installed the pin blocks. Fabricated and installed rear pins into the pin blocks. Installed fuselage side of pin blocks. Installed front canopy hooks and blocks. Installed front and side canopy latches.
