Rear fusalage leveled with lazer. Front section slid into rear. Upper structure and firewall clamped in place. Measured numerous times. Template made for each wing attachment and used to set the width of the uper structure. Upper part drilled and then down tubes drilled. Finally rear where it meets the rear was drilled.
