Bens Web Site
Date:  12-3-2015
Number of Hours:  1.50
Brief Description:  Wing tip door
Right wing access door used to trace the outline of the left door. The shape is cut out using the fly cutter for the corners and cut inbetween. The back doubler was traced and cut out of 0.032" and drilled through from the outside. Sheet was held up to the outside and traced and then cut out. Trimmed to fit the hole in the end skin.
