Lined up nose skin with the bottom skin holes at the spar. Drilled holes through both into the spar and then proceded down each nose rib. Marked and drilled and followed plas to make the front strut atachment. Marked and cut the slot for the tiedown ring. Drilled the holes for atachment of the tiedown ring.
