Brief Description: Flaparon mounts and rear channel
Added outboard channel to spar 6. Bottom hole on rib 6 enlarged by drilling final channel. Hole enlarged to A5 for that hole only. Inboard channel/wing mount attached to rib 1. The doubler was misdrilled y 10 mm due to the measurement being to the middle of the rib flange. Should miss the fusalage mount and function properly. The inboard rib was mounted at the corect distance simpl by reversing the direction of the attachment angle. Flaparon mount to rib atached to 1,3,4,6 ribs per plans. Aligmnet to the rear of the rib and the top surface. Rear strut fitting and the the associated angles attached to rib 4. holes at this location increased to A5 per plans. Installed fuel tank channel.
