Setup fly cutter on scrap material then drilled the hole in the side of the tank. Bent the float per the plans and installed into the tank. The tangs on the right sender were bent during the bending of the float and sensor read out of range and had to be bent back. Readings of around 10 ohm full and 70 ohm empty with 1" of fuel in the bottom of the tank. Since it was already set up the left tank was done as well. Both tanks were checked for leaks and function with gasoline.
