Bens Web Site
Date:  7-9-2015
Brief Description:  Fuel Tank Test Fit
Attached fuel tank supports to the ribs. The one at 200mm has 5 holes instead of 4 per the plans. Fuel drain hole and outlet driled. Outlet needed to be bigger than largest drill bit so was done with a bur. Top skin template made from scrap by dupicating the holes while on filler neck. Will be used to locate hole to cut in top skin.
