Debured and primmed the rear channels inboard rib and asscoiated brackets. Primer has been changed to "green" zinc-phospate. Riveted rear spar doubler and inboard rib fittings and worked toward the wingtip. Rear strut fitting attached while assembling rib # 4 channel.
