Wing tip angles crimped and drilled as progressing down the wing tip and then duplcated on the bottom skin. The edge is marked and the top hole is drilled and the coresponding hole drilled in the wing tip angle. The skin is held up through the hole with a cleco to locate the skin while drilling the rest of the holes.
