Bens Web Site
CH-701SP
Drilled bottom skin
Leveled and made vertical the spar and trailing edge. Rib center lines were lined up through the holes as they were drilled leaving the rear channel. The trailing edge pieces both inboard and outboard had notches cut to clear the flaperon brackets.
CH-701SP Home
531
144
Left Wing
Right Wing
Tail
25
62
