Brief Description: HS Doubler Plates, Hinge Brackets & Stops
Final drilled doubler plates. Drill the nut plate rivet holes for the horns. This was new as one had to fix the nut plate in position with a nut and then drill the rivet holes - previously this was always done. Provision in the prime process was not made where these attached are to be made and some priming will be required again before riveting. Machine counter sinking followed after the holes were done.
