Drilled the middle hole in the bottom rudder rib to 3/8" to clear the rod end bearing, dissasembled the rudder, deburred the holes in the rib, and spot primed the rudder horn where I removed some of the primer to clearance it. Hopefully tomorrow there will be riveting...
