Bens RV-7
Date:  3-26-2008
Number of Hours:  2.50
Brief Description:  Trim Tab
Riveted the aft half of the trim tab hinge to the trim tab. This was slightly more complicated then I anticipated, since occasionally the hinge loop was in the way of the rivet squeezer yoke, and there was limited clearance to begin with. Next was the pop rivets on the ends of the trim tab. Then I removed the forward portion of the trim tab hinge from the elevator, where it was clecoed, deburred the holes, and trimmed and smoothed the ends. I then clecoed it back on to the elevator and used the pneumatic squeezer to set the rivets. Finally, I finished up with four pop rivets on the elevator trim spar. Trim tab complete! Nice and straight!
