Match drilled all the rivet holes. fit the rear top skin in place. Fit the cockpit rails in place. Match drilled the longerons using the prepunched holes in the skins. Fit the front seatbck support DO SOME RESEARCH ON VANSAIRFORCE.NET ON THE WD-808 PROBLEM.
