Brief Description: Finished build up of fiberglass transition of cano
Finished the fiberglass/epoxy build-up for the canopy to forward frame skin. I did this in many steps, sanding between each layup. This process took a lot of time. Once most of the build up was done, used autobody filler to smooth out irregularities. Finished by applying Stewart Systems EcoPrime primer and wet sanding (several times). It turned out pretty well. I'm glad I watched the related Van's videos and attended the demo at Oshkosh
